WAN NAT not working when source IP is from LAN
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-23-2011 06:46 PM - edited 03-04-2019 11:32 AM
Good Day,
I have configured my Cisco 881 and it is quite stable but now I am working on some minor details.
I have several Public WAN IP addresses which are NATing to internal web server. When I go to the WAN IP at port 80 from the Internet, the NAT works fine and it maps perfectly to the internal Web server. However, when I try the same same WAN IP from the LAN which contains the web server, the Router blocks the traffic and I get nothing back.
I have verified that I can get to the Inernet from the LAN but it seems that I cannot go bfrom the LAN to the Internet and back into the LAN via NAT.
Any ideas on where I should look and how to troubleshoot?
Warning: I'm a IOS N00b
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-23-2011 06:58 PM
Can you provide the configuration please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-23-2011 08:26 PM
Here is my config (cleaned)
FYI - The Loopback0 is redundant and I have been planning on removing it. I don't think that is the problem but maybe...
Building configuration...
Current configuration : 12802 bytes
! Last configuration change at 17:41:34 PCTime Mon Feb 21 2011 by tquinn
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname sjpc1_g
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-15289216
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-15289216
revocation-check none
rsakeypair TP-self-signed-15289216
crypto pki certificate chain TP-self-signed-15289216
ip source-route
ip dhcp excluded-address 192.168.50.1 192.168.50.9
ip dhcp excluded-address 192.168.50.50 192.168.50.254
ip dhcp pool ccp-pool1
import all
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
dns-server 4.2.2.1 4.2.2.2
ip cef
no ip bootp server
ip domain name mydomain.com
ip name-server 4.2.2.1
ip name-server 4.2.2.2
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn XXXXXXXXXX
username admin privilege 15 view root secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXX
crypto ctcp port 10000
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group sjpc1vnet1
key XXXXXXXXXXXXXXXXXXXXXXXXXX
dns 4.2.2.1 4.2.2.2
pool SDM_POOL_1
acl 150
save-password
netmask 255.255.255.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map dyn-map 10
set transform-set ESP-3DES-SHA
crypto map vpn client authentication list ciscocp_vpn_xauth_ml_1
crypto map vpn isakmp authorization list ciscocp_vpn_group_ml_1
crypto map vpn client configuration address respond
crypto map vpn 65535 ipsec-isakmp dynamic dyn-map
interface Loopback0
ip address 10.30.99.99 255.255.255.0
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 69.68.67.94 255.255.255.0 secondary
ip address 69.68.67.96 255.255.255.0 secondary
ip address 69.68.67.93 255.255.255.0 secondary
ip address 69.68.67.95 255.255.255.0 secondary
ip address 69.68.66.37 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map vpn
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.50.1 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip local pool SDM_POOL_1 172.16.10.1 172.16.10.254
ip forward-protocol nd
no ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool PASSIVEFTP 192.168.50.210 192.168.50.210 netmask 255.255.255.0 type rotary
ip nat inside source static tcp 192.168.50.101 443 interface FastEthernet4 30443
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.50.100 902 69.68.66.37 902 route-map SDM_RMAP_6 extendable
ip nat inside source static udp 192.168.50.100 902 69.68.66.37 902 route-map SDM_RMAP_4 extendable
ip nat inside source static tcp 192.168.50.201 9001 69.68.66.37 9001 route-map SDM_RMAP_7 extendable
ip nat inside source static tcp 192.168.50.100 22 69.68.66.37 20022 route-map SDM_RMAP_8 extendable
ip nat inside source static tcp 192.168.50.100 443 69.68.66.37 20443 route-map SDM_RMAP_5 extendable
ip nat inside source static tcp 192.168.50.101 22 69.68.66.37 30022 route-map SDM_RMAP_11 extendable
ip nat inside source static tcp 192.168.50.210 3389 69.68.66.37 53389 route-map SDM_RMAP_3 extendable
ip nat inside source static tcp 192.168.50.240 3389 69.68.66.37 54389 route-map SDM_RMAP_13 extendable
ip nat inside source static tcp 192.168.50.220 80 69.68.67.93 80 route-map SDM_RMAP_10 extendable
ip nat inside source static tcp 192.168.50.220 443 69.68.67.93 443 route-map SDM_RMAP_12 extendable
ip nat inside source static tcp 192.168.50.210 80 69.68.67.94 80 route-map SDM_RMAP_2 extendable
ip nat inside source static tcp 192.168.50.210 80 69.68.67.96 80 route-map SDM_RMAP_9 extendable
ip nat inside destination list PASSIVEACL pool PASSIVEFTP
ip route 0.0.0.0 0.0.0.0 69.68.66.1
ip access-list extended PASSIVEACL
remark Standard FTP Data and Comms
permit tcp any any range ftp-data ftp
remark Extra Ports for Passive Use Only
permit tcp any any range 48000 49999
logging trap debugging
access-list 2 remark Auto generated by SDM Management Access feature
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 172.16.10.0 0.0.0.255
access-list 2 permit 192.168.50.0 0.0.0.255
access-list 2 permit any
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp any host 69.68.67.93 eq www
access-list 100 permit tcp any host 69.68.67.94 eq www
access-list 100 permit tcp any host 69.68.67.95 eq www
access-list 100 permit tcp any host 69.68.67.96 eq www
access-list 100 permit ip 172.16.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 100 permit udp any host 69.68.66.37 eq non500-isakmp
access-list 100 permit udp any host 69.68.66.37 eq isakmp
access-list 100 permit esp any host 69.68.66.37
access-list 100 permit ahp any host 69.68.66.37
access-list 100 permit tcp any host 69.68.66.37 eq 53389
access-list 100 permit tcp any host 69.68.66.37 eq www
access-list 100 permit tcp any host 69.68.66.37 eq 20443
access-list 100 permit tcp any host 69.68.66.37 eq 20022
access-list 100 permit udp any host 69.68.66.37 eq 902
access-list 100 permit tcp any host 69.68.66.37 eq 902
access-list 100 permit tcp any host 69.68.66.37 eq 9001
access-list 100 permit tcp any host 69.68.66.37 eq 22
access-list 100 permit tcp any host 69.68.66.37 eq 443
access-list 100 permit tcp any host 69.68.66.37 eq cmd
access-list 100 deny tcp any host 69.68.66.37 eq telnet
access-list 100 deny udp any host 69.68.66.37 eq snmp
access-list 100 permit ip any any
access-list 100 permit tcp any gt 1023 host 69.68.66.37 eq ftp
access-list 100 permit tcp any gt 1023 host 69.68.66.37 eq ftp-data
access-list 100 permit tcp any host 69.68.66.37 range 48000 49999
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 172.16.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.50.0 0.0.0.255 any
access-list 101 permit ip any any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit tcp 172.16.10.0 0.0.0.255 host 192.168.50.1 eq 22
access-list 102 permit tcp 192.168.50.0 0.0.0.255 host 192.168.50.1 eq 22
access-list 102 permit tcp 172.16.10.0 0.0.0.255 host 192.168.50.1 eq 443
access-list 102 permit tcp 192.168.50.0 0.0.0.255 host 192.168.50.1 eq 443
access-list 102 permit tcp 172.16.10.0 0.0.0.255 host 192.168.50.1 eq cmd
access-list 102 permit tcp 192.168.50.0 0.0.0.255 host 192.168.50.1 eq cmd
access-list 102 permit tcp 192.168.50.0 0.0.0.255 host 192.168.50.1 eq telnet
access-list 102 deny tcp any host 192.168.50.1 eq 22
access-list 102 deny tcp any host 192.168.50.1 eq www
access-list 102 deny tcp any host 192.168.50.1 eq 443
access-list 102 deny tcp any host 192.168.50.1 eq cmd
access-list 102 deny udp any host 192.168.50.1 eq snmp
access-list 102 permit ip any any
access-list 103 remark NAT ACL
access-list 103 remark CCP_ACL Category=18
access-list 103 deny tcp host 192.168.50.240 eq 3389 any
access-list 103 deny tcp host 192.168.50.220 eq www any
access-list 103 deny tcp host 192.168.50.220 eq 443 any
access-list 103 deny tcp host 192.168.50.101 eq 22 any
access-list 103 deny ip 192.168.50.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 103 permit ip 192.168.50.0 0.0.0.255 any
access-list 103 deny tcp host 192.168.50.210 eq 3389 any
access-list 103 deny tcp host 192.168.50.210 eq www any
access-list 103 deny tcp host 192.168.50.100 eq 443 any
access-list 103 deny tcp host 192.168.50.100 eq 22 any
access-list 103 deny udp host 192.168.50.100 eq 902 any
access-list 103 deny tcp host 192.168.50.100 eq 902 any
access-list 103 deny tcp host 192.168.50.201 eq 9001 any
access-list 104 remark CCP_ACL Category=2
access-list 104 deny ip host 192.168.50.210 172.16.10.0 0.0.0.255
access-list 104 permit tcp host 192.168.50.210 eq www any
access-list 105 remark CCP_ACL Category=2
access-list 105 deny ip host 192.168.50.210 172.16.10.0 0.0.0.255
access-list 105 permit tcp host 192.168.50.210 eq 3389 any
access-list 106 remark CCP_ACL Category=2
access-list 106 deny ip host 192.168.50.100 172.16.10.0 0.0.0.255
access-list 106 permit udp host 192.168.50.100 eq 902 any
access-list 107 remark CCP_ACL Category=2
access-list 107 deny ip host 192.168.50.100 172.16.10.0 0.0.0.255
access-list 107 permit tcp host 192.168.50.100 eq 443 any
access-list 108 remark CCP_ACL Category=2
access-list 108 deny ip host 192.168.50.100 172.16.10.0 0.0.0.255
access-list 108 permit tcp host 192.168.50.100 eq 902 any
access-list 109 remark CCP_ACL Category=2
access-list 109 deny ip host 192.168.50.201 172.16.10.0 0.0.0.255
access-list 109 permit tcp host 192.168.50.201 eq 9001 any
access-list 110 remark CCP_ACL Category=2
access-list 110 deny ip host 192.168.50.100 172.16.10.0 0.0.0.255
access-list 110 permit tcp host 192.168.50.100 eq 22 any
access-list 111 remark CCP_ACL Category=2
access-list 111 deny ip host 192.168.50.210 172.16.10.0 0.0.0.255
access-list 111 permit tcp host 192.168.50.210 eq www any
access-list 112 remark CCP_ACL Category=2
access-list 112 deny ip host 192.168.50.220 172.16.10.0 0.0.0.255
access-list 112 permit tcp host 192.168.50.220 eq www any
access-list 113 remark CCP_ACL Category=2
access-list 113 deny ip host 192.168.50.101 172.16.10.0 0.0.0.255
access-list 113 permit tcp host 192.168.50.101 eq 22 any
access-list 113 deny ip host 192.168.50.220 172.16.10.0 0.0.0.255
access-list 113 permit tcp host 192.168.50.220 eq 22 any
access-list 114 remark CCP_ACL Category=2
access-list 114 deny ip host 192.168.50.220 172.16.10.0 0.0.0.255
access-list 114 permit tcp host 192.168.50.220 eq 443 any
access-list 115 remark CCP_ACL Category=2
access-list 115 deny ip host 192.168.50.240 172.16.10.0 0.0.0.255
access-list 115 permit tcp host 192.168.50.240 eq 3389 any
access-list 150 remark Split Tunnel
access-list 150 permit ip 192.168.50.0 0.0.0.255 172.16.10.0 0.0.0.255
no cdp run
route-map SDM_RMAP_11 permit 1
match ip address 113
route-map SDM_RMAP_10 permit 1
match ip address 112
route-map SDM_RMAP_13 permit 1
match ip address 115
route-map SDM_RMAP_12 permit 1
match ip address 114
route-map SDM_RMAP_4 permit 1
match ip address 106
route-map SDM_RMAP_5 permit 1
match ip address 107
route-map SDM_RMAP_6 permit 1
match ip address 108
route-map SDM_RMAP_7 permit 1
match ip address 109
route-map SDM_RMAP_1 permit 1
match ip address 103
route-map SDM_RMAP_2 permit 1
match ip address 104
route-map SDM_RMAP_3 permit 1
match ip address 105
route-map SDM_RMAP_8 permit 1
match ip address 110
route-map SDM_RMAP_9 permit 1
match ip address 111
control-plane
banner exec ^C
% Password expiration warning.
Use a good password buddy!
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 101 in
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
