WAN on Cisco 877
info
Is it possible to set up a WAN interface on a FastEthernet interface of a Cisco 877 Adsl Router ?
Due to my ISP, i've to use an external VDSL modem and must connect it to my cisco 877 router (and leave it's adsl interface unused).
But i don't know how to set up a wan port, other than the adsl interface itself (dialer0), on my cisco.
Thanks for any help.
Levente
4 Accepted Solutions
paolo bevilacqua
Yes, put one Fa port in Vlan2 and configure Vlan2 as needed.
Please configure like below to get create the layer 3 interface
interface vlan 1
ip address x.x.x.x x.x.x.x
no shut
interace vlan 2
no shut
Then set the ethernet ports to the appropriate vlans
interface fa0/3
switchport access vlan 1
interface fa0/4
switchport access vlan 2
Please rate the all helpfull posts.
Naidu.
You should have "mtu 1492", not "ip mtu" on the dialer interface.
And disable firewall, it's useless and slows you done.
Note it's possible that the 877 will not keep up with VDSL speeds.
On vlan 1 and 2, mss adjust should be 1452.
Check attached document. Cisco now makes 880 router with VDSL interface, these would keep up.
Thanks for the nice rating and good luck!
7 Replies 7
paolo bevilacqua
Yes, thanks. And how can i do that ?
I mean, i know how configure vlan on a FastEthernet port but after ?
I'm a real beginner in cisco word so sorry for that kind of question...
interface vlan 1
no shut
interace vlan 2
no shut
interface fa0/3
interface fa0/4
Naidu.
Thanks for your help, i come back to this just now, a few week later.
This is the config i made (some like ATM were already configured, i add VLAN 3) :
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description DSL via Belgacom BBox
switchport access vlan 3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address xxx.xxx.xxx.90 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1412
interface Vlan2
description $FW_INSIDE$
ip address xxx.xxx.xxx.60 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Vlan3
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nbar protocol-discovery
ip flow ingress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxx
ppp chap password xxxxxxxxx
ppp pap sent-username xxxxxxxxx
password xxxxxxxx
no cdp enable
So, i've tried to configure a WAN port on the Eth3 port and link to it an externat "Belgacom" adsl modem (i'll switch soon to VDSL2 that my cisco 877 do not support, so i need the external modem (BBox) used in "bridge" mode).
I created a Vlan 3 and set the Eth3 port to it. And it seems to work, i've internet access from machines on the others vlans.
But on the router, the CD led (carrier detect i suppose) is still flashing and the adsl interface tries to connect.
So i've disabled the ATM interface.
All seems correct for you ? I've a very little experience with routers.
Thakns,
1° So, I change on Dialer0 : mtu 1492 in stead of ip mtu 1452.
2° What speeds you think i can hope with vdsl with the 877 ?
