ISDN Router 1812j - It won't reset the caller time out parameter
rojiroji123
I am having a problem about the caller time out.
#dialer idle-timeout 180 either
So the ISDN call will be disconnect after 180 sec.
However even there is traffic on the ISDN line, it will disconnect after 180 sec.
For example I PING -t command to the destination IP address, it will start dialing out after I run the PING command from srouce PC, but it will disconnect after 180 sec even continue to PING.
I checked the remaining time by the command #show caller timeouts
It won't reset the remaining Timer parameter.
  Line           User               Limit     Remaining Timer Type
  BR0:1          -                  00:03:00  00:00:49  Dialer idle
Here is the config which I think related ISDN dial.
Please advise why caller timer won't reset.
[Config]
interface BRI0
ip address negotiated
ip virtual-reassembly
encapsulation ppp
dialer string 03********
dialer-group 1
isdn switch-type ntt
isdn point-to-point-setup
no cdp enable
ppp authentication chap callin
ppp chap hostname ***
ppp chap password 0 ***
crypto ipsec client ezvpn EzVPN-client
ip route 172.100.133.0 255.255.255.0 BRI0
access-list 101 permit ip host 10.90.1.2 host 172.100.133.5
dialer-list 1 protocol ip list 101
Sean
rojiroji123
Can anyone knows how to reset the time out parameter?
Can you pls check with "debug dialer packet" to see whether your traffic is interesting or not as per ISDN?
This link may help you.
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a0080094eb7.shtml
Regards...
-Ashok.
With best regards...
Ashok
Hi, Ashok.
The link is very useful.
Somehow now works fine.
It reset the Idle Time when PING thru BRI port.
I did not change anything but now work fine.
It is very strange.
But this is good experience for me to understand the architecture.
Sean
Actually, I found the issue.
After I added this line.
access-list 101 permit ip any host 172.100.133.5
So, after I add "any" for the source ip then it reset the idle timeout parameter.
But I do not get it.
Because I can dial out only from the host "10.90.1.2"
So the host IP address is correct.
I want to dial only if specific host request to the router.
Any idea why this is not working.
