WAN redundancy with HSRP and VPN IPsec, problem adding new tunnels
Hi, I have a topology with two Cisco routers 891 where I am doing other remote vendors to have as a peer the HSRP virtual address to set up the VPN. The problem is the client wants to add more sites via CCP (Cisco Configuration Professional) and due to the HSRP configuration is done through CLI, the crypto map assignation on WAN interface is overwritten and created tunnel goes down because it can´t  establish  virtual address connection.
The only solution i have found is to reconfigure through CLI the crypto map redundancy on WAN interface but this is a Customer problem who does not have the skills to set up this way, also wants to add and delete tunnels graphically respecting redundancy.
Is there any option or missing configuration to solve this problem?
This is the scenario:
Active router´s configuration:
version 15.0
hostname GAIRET_1
boot-start-marker
boot-end-marker
logging buffered 52000
no logging console
no aaa new-model
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FTX151404HR
username gairet privilege 15 secret 5 $1$/FlP$ZJpvjKBYK07.czLV/94ob/
username ccpuser privilege 15 secret 5 $1$Y4Nq$2DOtuuo3tiLlH5jS7VmI8/
track 1 interface FastEthernet8 line-protocol
track 2 interface Vlan1 line-protocol
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key gairet address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
mode transport
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
match address 100
reverse-route
crypto dynamic-map SDM_DYNMAP_1 2
set transform-set ESP-3DES-SHA1
match address 101
reverse-route
crypto dynamic-map SDM_DYNMAP_1 3
set transform-set ESP-3DES-SHA2
match address 102
reverse-route
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface FastEthernet0
ip address 201.116.40.150 255.255.255.240
duplex auto
speed auto
standby 1 ip 201.116.40.151
standby 1 priority 150
standby 1 preempt
standby 1 name VPNHA
standby 1 track 2 decrement 100
crypto map SDM_CMAP_1 redundancy VPNHA   /// This conf. is overwritten by "crypto map SDM_CMAP_1" after a new VPN is added on CCP
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 192.0.0.237 255.255.255.0
ip tcp adjust-mss 1452
standby 0 ip 192.0.0.236
standby 0 priority 150
standby 0 preempt
standby 0 track 1 decrement 100
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 FastEthernet8 permanent
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 192.0.0.0 0.0.0.255 192.0.30.0 0.0.0.255
access-list 101 remark CCP_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 192.0.0.0 0.0.0.255 192.0.28.0 0.0.0.255
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 192.0.0.0 0.0.0.255 192.0.2.0 0.0.0.255
no cdp run
control-plane
Standby router´s configuration:
version 15.0
hostname GAIRET_2
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO891-K9 sn FTX1513017R
username gairet privilege 15 secret 5 $1$ARWh$Tp9XeX5pWXThh99qQOmsm0
encr 3des
group 2
mode transport
mode transport
mode transport
match address 100
reverse-route
match address 101
reverse-route
match address 102
reverse-route
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
ip address 201.116.40.149 255.255.255.240
no ip route-cache
duplex auto
speed auto
standby 1 preempt
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.0.0.238 255.255.255.0
no ip route-cache
standby 0 preempt
interface Async1
no ip address
encapsulation slip
no ip route-cache
ip http server
no cdp run
control-plane
Alejandra Rodríguez
0 Replies 0
