WAN Test Upgrade - tool
damianpablo
Hi, everybody its me  again.
well, i have next one problem.
My ISP realized an upgrade of my bandwidth, how can i do check my really bandwidth?
there are tool or command in my router?
thanks
There are several free tools, which can be found on the Internet, that can generate a volume of traffic. If you can place a tool on both ends of your link, you can verify its throughput.
Also, there are public tools that can be used to test bandwidth to test servers on the Internet.
e.g.:
speedtest.net
www.bandwidthplace.com
openspeedtest.com
speedof.me
testmy.net
prinaidu
You might want to post this question under-
Cisco Support Community /Network Infrastructure WAN,/Routing and Switching /WAN Testing
And this post might be helpful-
https://supportforums.cisco.com/t5/wan-routing-and-switching/wan-testing/m-p/1591983
Priya
Thanks but it is not necessary in this case. i need tool or cli which indicate my bandwight (Mbps)
e.g.:
speedtest.net
openspeedtest.com
speedof.me
testmy.net
