WARNING: Any system reset will change the system operating mode which can result in degradation of system performance. To eliminate this from occurring, remove Module 9 DFC or replace with a system compatible DFC.”
pravin.redekar
                  Hi I am facing problem with 7600-ES+20G3C card
David White
Hi Pravin,
Have a look at this discussion and see if it doesn't answer your question.
https://supportforums.cisco.com/thread/2169636
Sincerely,
David.
I am facing problem with 7600-ES+20G3C card which is not getting powered up with RSP720-3GXL-GE,
IOS version of the router is c7600rspsp72043_rp-ADVIPSERVICES_M, version 12.2(33) SRD6
Please find output of Show Module as below, Kindly suggest a solution for the same.
