looping when traceroute
prashantrecon
        Hi All,
I have dynamic nat on the router
ip nat pool route  202.15.16..224  202.15.16.224  netmask 255.255.255.248.
ip nat inside source list 166 pool route overload.
ip route 0.0.0.0 0.0.0.0 202.15.16.x
with above config everthing works fine.when i  excute show ip nat translations i get correct output.
when i do traceroute from outside network to 202.15.16.224
output reaches to first isp router as 202.15.16.X than to 202.15.16.224 and agin to 202.15.16.x this looping goes on to 30 hops.
Can i know why this is happening .But i am able to  access the internet, everything works fine.
5 Replies 5
Raju Sekharan
You are using dynamic nat. Nating will happen only from inside interface to outside interface. Also it will allow the reply packets for packets originated from inside
If you ping from outside to inside, it won't work.
if you need outside to inside access, you need to configure static nat
It is looping becasue your default route is pointing back to 202.15.16.X
/Raju
** rate if the post helps***
Hi rajs2
Thanks for explanation.
The thing is  isp has provided ip .I have already configured static nat for some servers . and for lan range i have carried out dynamic pat.
I have to point out route to 202.15.16.x as it is isp end.
So there any way to prevent this,Thus it have any effect on the traffic.(loops)
There is no issue with this. Only if someone tries to reach a non-used IP, this will happen
Hi Prashant,
Raj is correct whenever you will do ping to any ip of pool it will reach to the destination with any looping...as you are pinging to one of ISP IP it is going back to natted ip that is other end of ISP ip...so it is getting looped but I dont think u will face the same issue while doing a ping or trace to pool ip.
Leave it as it is..it is not going to affect ur traffic or not lead to any issue.
--Amit
Pls rate helpful info.
Thanks amit and rajs2
