wccp and gre on 4500
vanoverschelde
On which IOS version for the 4500 series is WCCP with GRE possible?
We have sup IV and sup 6-E.
jsivulka
Level 5
Level 5
Taking these three points together, the following configuration is required if you want WCCP interception to be handled completely in hardware on the 4500/Sup720 or 6-E.
- GRE or L2 forwarding
- Mask assignment
- Inbound redirection
- No 'ip wccp redirect exclude in'
This will require you to reverse the logic of how your service groups are applied:
- 'ip wccp web-cache redirect in' on client-facing interfaces
- 'ip wccp 95 redirect in' on internet-facing interfaces
Jerry Ye
Hi, The only WCCP feature supported on C4500 is WCCP version 2 Layer 2 Redirection.
You can find the information from C4500 IOS software release note:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html#wp757989
HTH,
jerry
I'm curious if you know the answer to this question.
I'm currently testing the transparent redirection of network traffic using wccp on a 4507 with Sup-IV and a BlueCoat Proxy SG.
I'm getting the following from the debugs and show commands. Any idea what the problem is? I have L2 forwarding enbaled on the BlueCoat. Time for me to open a case with TAC?
4507-1#debug ip wccp events
4507-1#debug ip wccp packets
Oct 28 14:54:11.404: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
Oct 28 14:54:11.404: WCCP-EVNT:wccp_copy_wc_assignment_data: allocate orig hash info (40 bytes)
Oct 28 14:54:11.404: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
Oct 28 14:54:11.404: WCCP-PKT:D01: Sending I_See_You packet to 10.1.4.23 w/ rcv_id 00000001
SPNC-4507-2#
Oct 28 14:54:21.403: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
Oct 28 14:54:21.403: WCCP-EVNT:wccp_copy_wc_assignment_data: allocate orig hash info (40 bytes)
Oct 28 14:54:21.403: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
Oct 28 14:54:21.403: WCCP-PKT:D01: Sending I_See_You packet to 10.1.4.22 w/ rcv_id 00000002
Oct 28 14:54:21.403: WCCP-EVNT:wccp_update_assignment_status: enter
Oct 28 14:54:21.403: WCCP-EVNT:wccp_update_assignment_status: exit
Oct 28 14:54:21.403: WCCP-EVNT:D01: Here_I_Am packet from 10.1.4.23 w/bad assign method 00000001, was offered 00000002
Oct 28 14:54:21.403: WCCP-EVNT:D01: Here_I_Am packet from 10.1.4.23 with incompatible capabilites
SPNC-4507-2#
Oct 28 14:54:21.403: WCCP-PKT:D01: Sending I_See_You packet to 10.1.4.23 w/ rcv_id 00000003
SPNC-4507-2#
Oct 28 14:54:31.403: WCCP-EVNT:D01: Here_I_Am packet from 10.1.4.22 w/bad rcv_id 00000003
Oct 28 14:54:31.403: WCCP-PKT:D01: Sending I_See_You packet to 10.1.4.22 w/ rcv_id 00000004
Oct 28 14:54:31.403: WCCP-EVNT:wccp_update_assignment_status: enter
Oct 28 14:54:31.403: WCCP-EVNT:wccp_update_assignment_status: exit
Oct 28 14:54:31.403: WCCP-EVNT:D01: Here_I_Am packet from 10.1.4.23 w/bad assign method 00000001, was offered 00000002
Oct 28 14:54:31.403: WCCP-EVNT:D01: Here_I_Am packet from 10.1.4.23 with incompatible capabilites
Oct 28 14:54:31.403: WCCP-PKT:D01: Sending I_See_You packet to 10.1.4.23 w/ rcv_id 00000005
4507-1#sh ip wccp 1 detail
WCCP Client information:
WCCP Client ID: 10.1.4.23
Protocol Version: 2.0
State: NOT Usable
Redirection: L2
Packet Return: L2
Packets Redirected: 0
Connect Time: 00:05:09
Assignment: MASK
WCCP Client ID: 10.1.4.22
State: NOT Usable
Redirection: L2
Packet Return: L2
Connect Time: 00:04:59
Assignment: MASK
andyphillipstoo
WCCP is not supported on the Sup 6-E. I wonder why? I am trying to find out.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/wccp.html
Regards, Andy
