03-24-2023 12:23 PM
Hello WCCP Experts,
I am running WCCP on CSR1000V on VMware. The HTTPS traffic is not being redirected.
GigabitEthernet1 10.0.0.1 YES NVRAM up up
GigabitEthernet2 10.34.198.1 YES NVRAM up up
GigabitEthernet3 xx.yy.25.1 YES NVRAM up up (to Internet)
ip wccp check services all
ip wccp source-interface GigabitEthernet1
ip address 10.0.0.1 255.255.255.0
ip wccp 70 redirect in
ip ospf authentication key-chain KC-5
negotiation auto
no mop enabled
no mop sysid
service-policy output NTP1-ACL-POLICY
ip wccp 70 redirect-list 150 group-list 10
Squid Proxy:
ip access-list standard 10
10 permit 10.34.198.3
ip access-list extended 150
10 permit tcp any any eq 443
Cisco-CSRv-1#show ip wccp
Global WCCP information:
Router information:
Router Identifier: 10.0.0.1
Configured source-interface: GigabitEthernet1
Service Identifier: 70
Protocol Version: 2.00 (minimum)
Number of Service Group Clients: 0
Number of Service Group Routers: 0
Total Packets Redirected: 0
Process: 0
CEF: 0
Platform: 0
Service mode: Open
Service Access-list: -none-
Total Packets Dropped Closed: 0
Redirect access-list: 150
Total Packets Denied Redirect: 0
Total Packets Unassigned: 0
Group access-list: 10
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total GRE Bypassed Packets Received: 0
Process: 0
CEF: 0
Platform: 0
Any input is greatly appreciated. Thank you!
03-25-2023 02:00 AM
Make sure on ESXi - Promiscuous Mode setting under the vSwitch Security tab from Reject to Accept
WCCP reference :
03-25-2023 05:38 AM
Thank you for replying Balaji!
I enabled the Promiscuous Mode, but still the traffic not being directed. The ACL-10 and ACL-150 are not being hit also.
Audie
03-25-2023 08:28 AM
Enable debug and check on CSR. what proxy you using ?
what is the outcome of
show ip wccp web-cache detail
03-25-2023 08:49 AM
Balaji,
Cisco-CSRv-1#show ip wccp 70 detail
No information is available for the service.
Still not being directed
Thanks!
I am using Squid Proxy. When statically enabled on browser, it works
03-25-2023 09:12 AM
for the WCCP to work to redirect the Squic Proxy should see on the CSR Router.
On the Linux side any Firewall enabled check (iptables) and make sure selinux disabled.
also, make sure Squid configure for WCCP v2
# squid -v | grep enable-linux-netfilter | grep enable-wccpv2
03-27-2023 05:08 AM - edited 03-27-2023 06:18 AM
Now the CSR is seeing the Squid:
WCCP Client information:
WCCP Client ID: 10.34.198.100
State: NOT Usable (Initializing)
Redirection: None
Packet Return: None
Assignment: None
Connect Time: 00:00:10
Redirection: None
Packet Return: None
Assignment: None
Redirection: None
Packet Return: None
Assignment: None
Update: I see the Squid is receiving the request form the browser (10.34.198.101), but it is not replying...one-way traffic
Thanks...Audie
03-27-2023 06:51 AM
Does squid knows how to route back to CSR1Kv ?
03-27-2023 06:56 AM
Yes....the inner interface is in the same subnet as the router and browser (10.34.198.0/24)....thank you
03-27-2023 07:14 AM
i was closly looking your show output :
State: NOT Usable (Initializing) - you have communication but both not agreed yet.
03-27-2023 09:15 AM
I think the issue is within Squid or Ubuntu 20.04.
