WEB SERVER on Local IP
dhavaltandel
Hi all
-I have web server setup on private ip address.
-I have cisc0 2621 with public ip.
-Now i wan my web server to access from out side.
-I did translation configuration on cisco router like this
ip nat inside source static tcp 192.168.1.1 80 xx.xx.xx.xx 80 extendable
ip nat inside source static tcp 192.168.1.1 53 xx.xx.xx.xx 53 extendable
ip nat inside source static udp 192.168.1.1 53 xx.xx.xx.xx 53 extendable
-My Disign is like this
ISP CLOUD------(F0/0-IP-XX.XX.XX.XX)2621(F0/1)-------SWITCH(NON MANAGABLE)--------LAN[INCLUDE WEB SERVER(192.168.1.1)]
-By doing above trasnslation webserver is not able to access from out side.
-But if i put web server directly on public ip address i can browse the website.(which feels me like web server configuration is okay)
My question is - IS THERE ANYTHING ELSE NEED TO CONFIGURE.......?
Thanks in advance....
regarda
Dhaval
Hi Dhaval
Instead of defining pool statement and overloading over that can you try defining the overload statement indicating your fastethernet interface..
ip nat inside source list 10 interface FastEthernet0/0 overload
Also can you remove the other subnet (10.1.1.0/24) if it is not being used...
regds
10 Replies 10
jolmo
Level 4
Level 4
Hi Dhaval
I think you missed:
interface F0/0
ip nat outside
interface F0/1
ip nat inside
Please, try it and let us know
Hope this helps
spremkumar
Level 9
Level 9
Hi Dhaval
Can you post out the full config of your router here ?
Also are you able to ping the public ip which you have configured in the nat statement from outside ?
regds
Hi all,
find attechment for full configuration. only ip information is not available as you can understand the reason.
thanks
dahval
Hi all
here is the attechment for router config.
Dhaval
Hi Dhaval
regds
can u explain these couple of commands:
ip nat pool dhara 61.11.35.136 61.11.35.136 netmask 255.255.255.0
ip nat inside source list 10 pool dhara overload
ip nat inside source static tcp 192.168.1.1 21 xx.xx.xx.xx 21 extendable
ip nat inside source static tcp 192.168.1.11 8081 xx.xx.xx.xx 8081 extendable
ip nat inside source static tcp 192.168.1.1 22 xx.xx.xx.xx 22 extendable
10xs
-POOL DHARA is configured for inside users to access internet.
-rest all has same concept its directing the request coming on router for WWW,FTP,DNS,SSH request to internal server which is configured with private ip address.
regards
Dhaval
Hello PremKumar.
I did same but still not able to access my website from out side.
rest of all is working as it is after new configuration..
thanks
Dhaval
HI PremKumar.
Thanks, I got the website browsing from outside now.
Dhaval
Hi Premkumar,
Can you explain me what cause of configuration prob it was..?
Dhaval
