WebUI no menu - Router 1100 series
djazu01
iam trying to set my router trough the webui by ther is no menu.Any idea where the problem is ? :
What about the blue Arrow up side left?
7 Replies 7
  You landed in the statistics dashboard. Have you tried the "engine" symbol on the top?
Yes i tried
yes it worked, ive ovelooked this. Thank you so much
marce1000
 - Did you configure basic settings before using WebUI : https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-8/cisco_1100_series_swcfg_xe_16_8_x/cisco_1100_series_swcfg_xe_16_10_x_chapter_011001.html
 M.
Yes exactly i did this before i logged in the webui
Aria
Can I ask what you did to resolve this issue? For me in the web ui I only can see the Dashboard and Monitoring menu.
Aria
