What are mean "rights to use licenses" ?
ComstorFR
Hi all,
Can someone explain to me, in practice and  compared to other licenses,  what it means   "rihgts to use
licenses " ? what are their real usefulness. when will it be used ?
Best regards
Richard Burts
If we understood the context of your question we might be able to give better answers.
In general a "right to use" license gives you the right to use the software but not the right to modify the software and perhaps not the right to provide the software to others. Other types of licenses could give you the right to modify the software, or to incorporate the software into other products, or the right to provide ccopies of the software to others.
Rick
Rick
Richard Burts
Rick
Rick
Thanks a lot Rick for your reply and your information
