What are OIDs (and MIB id) to track queueing QOS dropped packets ?
plouapre1
In which MIB and which OIDs are availiable onto 7600 plateform to get in/out qos dropped packets counters available onto the show queueing interface  ?
My configuration: 7609S-RSP720-SRB3-DFC
#sh queueing interface gi2/18 | b dropped
  Packets dropped on Transmit:
    queue     dropped  [cos-map]
    1                1  [0 1 ]
    2                0  [2 3 4 ]
    3                0  [6 7 ]
    4                0  [5 ]
  Packets dropped on Receive:
    1                1  [0 1 2 3 4 5 6 7 ]
Thks in advance.
2 Accepted Solutions
Laurent Aubert
Hi Patrice,
Please try CISCO-SWITCH-QOS-EXT-MIB but it requires SRC minimum.
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-SWITCH-QOS-MIB.my
Laurent.
Hi Patrice,
Thanks for the rating !! I appreciate.
CISCO-QUEUE-MIB is a legacy MIB which had been replaced by CISCO-CLASS-BASED-QOS-MIB and is more oriented on software QoS so I don't think it will answer to your needs.
Laurent.
Laurent Aubert
Hi Patrice,
Laurent.
Thks a lot Laurent for this feed back. I ve checked OID descriptions and it looks very interesting. We will test it even if i would appreciate to get a workaround into SRB3. A colleague ask me to check MIB CISCO-QUEUE-MIB but i don't find anythings interesting. What is your feeling ?
It is the first time i use this cisco support community and i hope my evaluation looks OK as i appreciate a lot your feed back. Thks again for your quick response. Let me know if i was wrong.
Hi Patrice,
Laurent.
Does anyone know OID for cisco ASA  to pull out users that log into the vpn. Need help.
