What command can be used to see RD value in peer PE in MPLS?
wfqk
Level 5
Level 5
Hi Here a topology, PE1 and PE2 have different RD value as the below in MPLS. From PE2, what command can be used to see routes which are from PE1 and are attached by RD 100:1? Thank you
PE1
vrf abc
RD 100:1
PE2
vrf abc
RD 100:2
Francesco Molino
You can use the command:
Sh ip bgp vpnv4 rd xx:xx
Take a look on this link:
http://www.cisco.com/c/en/us/td/docs/ios/iproute_bgp/command/reference/irg_book/irg_bgp5.html#wp1163912
PS: Please don't forget to rate and mark as correct answer if this answered your question.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Thank you so much for your reply.
You are welcome to the case:
https://supportforums.cisco.com/discussion/13207666/rd-needs-be-changed-what-protocol-we-can-follow
You're  welcome. I will take a look on your new post later.
Francesco
