OSPF Routes
Hello All,
What if we get same exact route from two ABRs??
From two ASBR ??
One from ABR & One From ASBR ??
Prasanna Kumar Desireddy
Francesco Molino
The decision made by OSPF for routing is based on route type and cost globally.
Here is the route selection tie-breaker:
-Intra-area routes.
-Inter-area routes.
-External type 1 routes.
-External type 2 routes.
-Route with the lowest cost if the same type.
-If cost is the same both routes will be installed in the routing table and load balance occurs.
ABR will send LSA type 3 and 4.
ASBR will send LSA type 5 in addition of LSA 3 and 4.
The tiebreaker occurs if you're receiving same type route. However if asbr is sending type 5 (external) while you receive type 3 from abr, type 3 will be preferred.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
-Intra-area routes.
-Inter-area routes.
Francesco
