What does excessbits/int mean?
hfakoor222
The target is 128000,  its sustained at 128000 average over a second which I believe it means it can go over 128000 within that 1 second interval
I am not sure what the significance if the excess bits are
this is under the traffic-shape command under the interface
follow
Joseph W. Doherty
Excess is an allowance for when peak shaping (or policing) is configured rather than average shaping (or policing).
Basically, during a time interval (often much less than 1 second, often in the range 25 to 40 ms), this number of bits are "allowed" (much as the sustain value does too).  (Of course, when you exceed limits, excess is either queued [shaping] or dropped [policing].)
As I recall, some of Cisco's documentation does (or did) explain excess allowing to "borrow" extra bandwidth capacity, allowing a short "burst" of traffic, but still providing an overall average limit.
However, the common Cisco implementation, I believe, doesn't "borrow" but just adds/allows for a second allocation.  So, for example, for your posted target rate of 128 Kbps, average shaping/policing would only allow a sustained rate of 128 Kbps. But peak shaping/policing would allow a sustained rate of 256 Kbps.  (The latter, in such a implementation would, I believe, obtain the same effect as if the average was doubled.  I.e. 256 Kbps average shape/police same as 128 Kbps peak shape/police.)
hfakoor222
Thank you ~ any more answers to help c;arify this a little bit~ from what I read from James's this allows for a very short time the bit rate to go over the average/sustained. So would it get rolled into the average?
Any clarifications or further insight?
