What happens if a packet doesn't match any NAT entry?
Mitrixsen
Hello, everyone.
Here is my topology:
Imagine that the network on the left is some internal network with private IPs that are being translated into 9.9.9.x. If I issue the following configuration:
This means that anyone from the network on the right will be able to access Host1 via the IP 9.9.9.55 using Telnet.Since Static PAT is bidirectional, this also means that any replies coming from Host1 will be translated from 10.1.1.11 23 into 9.9.9.55 23.
Now, my question is, what exactly happens if a packet is received that doesn't match any of the Static PAT entries that I've configured? In a NAT course that I am following, the instructor created a packet with the port number set to 25 and the PAT router sent a TCP RST message in return.
However, in my topology, the router replies with an ICMP Destination Unreachable message which is used when there isn't a route for the destination (which R1 doesn't have).
So what exactly makes the router drop the packet? The lack of the NAT entry or the lack of a route? What if there isn't a NAT/PAT entry that would match the packet? Is the packet immediately dropped or is it just not translated and then dropped due to a lack of route?
Thank you.
David
9 Replies 9
NAT IP make it routable for router
If IP not NATing then router can not forward it and drop.
The first reason we use NAT is for routing' he hide private IP behind public IP
MHM
Friend now start to see what happened inside router
Use
Debug ip nat
Debug ip policy
Check output for both case
MHM
Hello
it will be because of the lack of translation before any lack of routing
if you look up nat order of translation it should show you the nat order regards domain-nat
Kind Regards
Paul
Joseph W. Doherty
In your topology, where is the 9.9.9.0/24 network?
Hello.
It isn't a network on its own, its just the range of "public" IP addresses that I use for the translation. xR3 has a route only for that IP address range.
Hello @Joseph W. Doherty
The assumption is that range is routable externally towards the nat rtr hence its being used for translation
Kind Regards
Paul
Joseph W. Doherty
"However, in my topology, the router replies with an ICMP Destination Unreachable message which is used when there isn't a route for the destination (which R1 doesn't have)."
(Sorry, my prior reply was a hint based on why the particular error was returned.)
Exactly - because the 9.9.9.0/24 is unknown to R1.  The static PAT statement is valid, but there's no route for the 9.9.9.5 IP.
I assume your instructor's example has a value route for both inside and outside IPs.
"So what exactly makes the router drop the packet?  The lack of the NAT entry or the lack of a route?"
Depends on whether going inside to outside or the converse because NAT and routing order of execution difers and what information is missing or invalid.
"What if there isn't a NAT/PAT entry that would match the packet? Is the packet immediately dropped or is it just not translated and then dropped due to a lack of route?"
If there's no matching NAT/PAT, then packet processed normally.  I.e. there's nothing to translate.
Assuming the actual NAT/PAT can be executed, unsure why CLI would allow an invalid statement, only an operation whose failure precludes execution of a subsequent translation would preclude its execution.
Possibly this will help: https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html
Addendum:
Again, my first reply was addressing the question why the particular error response.
My follow on reply further delved into answers for questions, which also depends on order of operations, but my first reply had noticed @paul driver had touched upon that in his first reply, but in my second reply, I forgot his first reply, and so needlessly provided the same reference rather than just refer to his original reply.
Giuseppe Larosa
Hello @Mitrixsen ,
the type of answer is platform dependent and also it depends on the config.
A firewall and all NGFW are  zone based  answers with a TCP RST when attempting an inbound conn from public internet.This happens on Cisco ASA,  Cisco ASA X,  Cisco  FTD,  Juniper  SRX,  Fortinet  Fortigate   and so  on.
An IOSXE  router configured with  ZBFW  + NAT   it   is  lkely  to do  the   same.
In your configuration using simple static NAT   the  router acts as a router and   it is stateless.   On  the other  hand sending an  ICMP unreach  is   more efficient  in terms of resources when a DoS attack is occurring.
Hope  to help
Giuseppe
