What in this configuration is causing to different routes for a subnet
nygenxny123
We have 2 subnetwork in our building
192.168.134.0 /23 and 192.168.133.0/24
The 134/135 has their "internet" traffice routed through a proxy server at another location...but the 133 network has "direct" access. Yesterday the 133 network lost internet access for a short time. Im trying to figure out what the difference is.
This is an MPLS network
plz see attachment
6 Replies 6
singhsaju
Level 4
Level 4
Can you post traceroutes to internet from 133 and 134 subnets?
Giuseppe Larosa
Hello Richard,
from the point of view of your router there is no difference
net 192.168.133.0/24
net 192.168.134.0/23
are both advertised on the EBGP session to the PE thanks to the OSPF redistribution into BGP.
Somewhere the net 192.168.133.0/24 is NATTED to access internet and the NAT device needs to have a return route to send back traffic.
This device that is different from the devices that processes net 192.168.134.0/23 could experience some form of failure on reaching the internet and so only net 192.168.133.0/24 was impacted or the return route was missing.
A detailed network diagram would be needed here but something can happened far from you and without any log on your router.
Also net 192.168.133.0/24 reaches the internet by going to where the prefix 0.0.0.0 is originated in the provider network inside your MPLS VPN (some other PE router for example that could be a C6500 with a FWSM module just to say)
Hope to help
Giuseppe
from the 134 subnet-for some reason we now cant ping out of that subnet
tracert 4.2.2.2
Tracing route to vnsc-bak.sys.gtei.net [4.2.2.2]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.135.252
2 4 ms 4 ms 5 ms 192.168.255.142
3 23 ms 23 ms 23 ms 192.168.255.133
4 24 ms 24 ms 24 ms 192.168.119.241
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
and now 133 subnet
1 <1 ms <1 ms <1 ms 192.168.133.252
2 4 ms 4 ms 4 ms 192.168.255.142
5 20 ms 20 ms 20 ms 9-172-1xx-63.act.net [65.xx.xxx.9]
6 22 ms 22 ms 22 ms t3-3-1-0-3.edge7.washington1.level3.net [4.7x.20
2.49]
7 21 ms 22 ms 22 ms ae-13-13.car1.washington1.level3.net [4.68.106.2
33]
8 23 ms 21 ms 31 ms vlan69.csw1.washington1.level3.net [4.68.17.62]
9 23 ms 22 ms 22 ms ge-5-0-51.hsa1.washington2.level3.net [4.68.121.
13]
10 22 ms 22 ms 21 ms vnsc-bak.sys.gtei.net [4.2.2.2]
Trace complete.
As you mentioned , traceroute shows that 134 subnet does not has "direct" access to internet whereas 133 subnet is properly NAT'ed/routed to internet .
Do you manage 192.168.119.241? Thats where NAT/PAT is happening.
Hello Richard
the first 4 IP hops are the same:
So the device that needs to be investigated is 192.168.119.241.
Here the two subnets receive different treatment.
Hope to help
Giuseppe
yes...
We manage the 192.168.119.241..
It is a c3850
3800 Software (C3825-ADVSECURITYK9-M)
so..all traffic is routed here
and this device is routing either directly to the intenet or it is not.
I ask cuz we have a proxy server that the .134
network must go through.
However the .133 bypasses the proxy and goes
directly to the internet
