Frame-relay traffic-shaping
harinirina
Hi all,
We have 2 sites connected to the main office via FR.
We've configured QoS on the frame-relay interface (it's a WIC-1T).
- When a "service-policy output" is applied on each serial interface, and the qos is tested only between one site and the main office, it works well.
- When there's a traffic from 2 sites to the main office, the policy-map is no more respected.
- We tried to use map-class and apply "frame-relay traffic-shaping" with class on serial interfaces, we can see the policy-map respected but the bandwidth is reduced, speed of transfert is really low.
We did the test with FTP and File copy between sites.
here's our config
- on main office
interface Serial0/1
description Liaison FR
ip address 10.10.10.1 255.255.255.248
encapsulation frame-relay IETF
no fair-queue
frame-relay interface-dlci 16
class QOS_FR
frame-relay interface-dlci 17
class QOS_FR
- on site 1
interface Serial0/1/0
ip address 10.10.10.2 255.255.255.248
ip route-cache flow
load-interval 30
no fair-queue
class QOS_FR
- on site 2
ip address 10.10.10.3 255.255.255.248
no fair-queue
clock rate 2000000
class QOS_FR
frame-relay lmi-type cisco
The config of the policy-map is the same on all router
class-map match-all CL_COPIE
match access-group name PRT_COPIE
class-map match-all CL_FTP
match access-group name PRT_FTP
policy-map PL_FTP
class CL_COPIE
bandwidth percent 50
class CL_FTP
bandwidth percent 20
ip access-list extended PRT_COPIE
permit tcp any any eq 445
permit tcp any eq 445 any
ip access-list extended PRT_FTP
permit tcp any any eq ftp-data
permit tcp any eq ftp-data any
permit tcp any eq ftp any
map-class frame-relay QOS_FR
service-policy output PL_FTP
9 Replies 9
Giuseppe Larosa
Hello Harinirina,
a default bandwidth of 56 kbps is used when you enable classi traffic shaping you need to provide some info about CIR inside the map-class
frame-relay cir {in | out} bps
see the link below
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_afrt_shp_ic_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1015363
you need to shape on both branch routers to less then the access link speed at central site: they cannot know if the other remote is sending traffic or not.
Hope to help
Giuseppe
Hi all,
thanks both for the reply.
Giuseppe,
is there a way to do the same thing on ethernet interface?
we do another test using FastEthernet, we used banwidth to change it but there's no impact.
Joseph,
would you to give more information about "Fix", which you mentionned on :
>> The "fix" is to traffic shape the sending sites such that their transmissions don't oversubscribe the receiver's link. <<
For example, if you had 3 sites, HQ and 2 branches, and all has 1 Mbps links to the FR cloud, snd both remotes might fill their 1 Mbps link sending traffic to the HQ, 2 Mbps traffic trying to egress the FR cloud to the HQ site will cause congestion. The fix would be to insure the transmission sum of the 2 brances to the HQ site doesn't exceed 1 Mbps. You could configure both branches with shapers that restrict them to 500 Kbps each, or branch 1 to 750 Kbps and brance 2 to 250 Kbps, etc.
PS:
Another fix would be to upgrade the HQ site to 2 Mbps (although with shapers to insure it doesn't send more than 1 Mbps to each branch).
Hello Harinirina,
the bandwidth command provides the reference bandwidth for the interface and for the modular QoS but it is not enough by itself.
On an FE you can use Class Based Shaping.
You need to define traffic classes and policy-map that specify what to do for traffic that is classified on each class in your case the desired action is shaping
The simpler shaper you can think of is
policy-map shape-all-512kbps
class class-default
shape peak 512000
int f0/0
service-policy output shape-all-512kbps
here you can take advantage of the built-in class-default that collects whatever doesn't match previous classes : here everything goes in class-default
as a reference use:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/reg_pkt_flow_per_cls.html
I used 512 kbps thinking of a remote site in a scenario with two remote sites and an head quarter.
Hope to help
Giuseppe
Hi all,
We'd like to ask more question
Joseph,
Can we applied the first fix (insure the transmission sum doesn't exceed 1Mbps) on whatever link (VSAT, ADSL, ...) and on whatever interface (FastEthernet, WIC ADSL, Serial, ...)?
what about the command to use, is it the "shape peak" applied on each class?
Giuseppe,
let's say we have a VSAT connection of 128 Kbps. The IDU is connected to a FastEthernet interface.
We'd like to use 50% of bandwidth for the port 445 and 20% for FTP.
So, do we need the configure 2 policy-map, one for limiting the total bandwidth and the other for specifying bandwidth per protocol? is it that or not?
in case we have an ADSL connection, can we do the same thing?
"Can we applied the first fix (insure the transmission sum doesn't exceed 1Mbps) on whatever link (VSAT, ADSL, ...) and on whatever interface (FastEthernet, WIC ADSL, Serial, ...)?"
If you're using a Cisco router, you should be able to shape on most interface types. (Actual WAN technology, other than actual bandwidth, not too important, it has more to do with interace type on router.)
"what about the command to use, is it the "shape peak" applied on each class? "
No, you would not shape each class, you would shape a parent class that in turn would have a subordinate policy.
e.g.
policy-map aChild
class realtime
priority percent 30
class gold
bandwidth remaining percent 60
class silver
bandwidth remaining percent 30
class scavenger
bandwidth remaining percent 1
class class-default
bandwidth remaining percent 9
policy-map aParent
class class-default
shape average ###
service-policy aChild
interface serial #
service-policy output aParent
(You could use either peak or average shaping, which to chose depends on whether you want to allow additional traffic bursts.)
Hello Harinirina,
different solutions are possible you can use a single policy-map with multiple traffic classes our you could use hierarchical policy-maps.
You can shape or use schedulers (queueing) as in Joseph's example.
You can apply modular QoS out an ATM (ADSL) interface.Depending on IOS versions and platforms you can apply the QoS to an atm subinterface or not in almost all cases you can apply it to the main interface even if a subif is defined.
see :
RT-TGR-AQUILA#sh run int atm0
Building configuration...
Current configuration : 137 bytes
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
service-policy output llq_voice
end
RT-TGR-AQUILA#
RT-TGR-AQUILA#sh policy-map llq_voice
Policy Map llq_voice
Class llq_voice
Strict Priority
Bandwidth 200 (kbps) Burst 5000 (Bytes)
Class class-default
RT-TGR-AQUILA#
RT-TGR-AQUILA#sh policy-map int atm0
ATM0
Service-policy output: llq_voice
Class-map: llq_voice (match-all)
9100240 packets, 1336196836 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip precedence 5
Queueing
Strict Priority
Output Queue: Conversation 264
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
85776090 packets, 46749841402 bytes
30 second offered rate 394000 bps, drop rate 0 bps
Match: any
RT-TGR-AQUILA#
Hope to help
Giuseppe
Thanks indeed for all your reply. They are extremelly helpful.
We'll use it.
Joseph W. Doherty
"When there's a traffic from 2 sites to the main office, the policy-map is no more respected. "
When you have multiple sites that can send traffic to one site, it can be easy to oversubcribe the one receiving site's bandwidth (from a cloud to it).
The "fix" is to traffic shape the sending sites such that their transmissions don't oversubscribe the receiver's link. The disadvantage of this, when only one site is sending, it can not take advanatage of bandwidth not being used by the other sending site(s).
If you do shape multiple sending sites, they don't have to be all in the same proportion. Also, although no oversubscription guarantees there won't be cloud egress congestion, you can configure shaping to allow some oversubscription.
PS:
One of the feature of MPLS vs. frame-relay is MPLS often can provide QoS so you can better manage congestion as traffic exits the cloud.
