04-04-2018 03:50 PM - edited 03-05-2019 10:13 AM
Ok let's say my internal network subnets are on 10.1.X.X /24, and the IP on the edge router that connects to the ISP is 50.50.50.49 and the ISP is 50.50.50.50. What is the IP I would use to NAT my 10.1.X network? I am not using 50.50.50.49 correct?
Solved! Go to Solution.
08-21-2018 08:17 AM
Lets say I have 2 different internal subnets.
Ok so if these two different internal subnets on the inside 2 different inside interfaces on the FW are natted to the same public IP, then that traffic goes to the edge router, how do I send let's say natted subnet 192.168.200.X to one public IP, then the the other subnet 192.168.300.X to let's say another gateway like a tunnel?
08-21-2018 08:18 AM
08-21-2018 10:30 AM
You can use PAT for all internet traffic. You would then no-nat the traffic that is going out a tunnel.
08-21-2018 10:44 AM
can you give me an example based on the info.
So if I have two internal subnets from FW being natted, then that traffic hits the edge router, how do I nat these?
