What is a Virtual Router?
khareapoorv
Please help me.
Danilo Dy
There are many definitions for a virtual router, depends on the situation.
One of them is an application that simulates a router. i.e. dynamips http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Another one is a protocol that advertise a "virtual router" (an abstract representation of master and backup routers acting as a group). Virtual Router Redundancy Protocol (VRRP) http://en.wikipedia.org/wiki/Virtual_router_redundancy_protocol
steve_miller
And of course VRF instances allow you to maintain and utilize separate routing tables for each instance. If you were to toss out "virtual router" that would be the first thing to pop into my head.
http://en.wikipedia.org/wiki/VRF
on high end routers like CRS you can logically partition the chassis and the linecards in so called virtual routers that will have separate management, interfaces, a share of resources.
Other vendors call virtual router the equivalent of an MPLS VRF
Hope to help
Giuseppe
