What is difference between default route and network route?
Kaleem33
i know about default route if packets not for your network then you can send it to your default route but i am not getting about network route what is this?
if you wanna go to any unknown networks you use default route like this: ip
route 0.0.0.0 0.0.0.0 192.168.3.2
but if wanna go to 192.168.1.0/24 network you use network route like this: ip
route 192.168.1.0 255.255.255.0 192.168.2.2
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
A default route is just a special network route. A network route tells you how to get to a specific network. A default route tells you how to get to everything else we have not specified.
e.g.
ip route 192.168.1.0 255.255.255.0 192.168.2.2 --> to get to network 192.168.1.0/24 go via 192.168.2.2
ip route 0.0.0.0 0.0.0.0 192.168.3.2 --> to get to all networks for which we have no specific route go via 192.168.3.2
John
you are saying that:
but if wanna go to any specific network you use network route like this: ip
am i right?
thank your for help and quick response:)
