What is maximuam site to site connection cisco router 2821
LopezLas11
Hi, i want to setup multiple site to site connection, between my headoffice and remote offices.
on HeadOffice, i've cisco router 2821, with IOS model:
c2800nm-adventerprisek9-mz.124-20.T.bin
There is no extra hardware module on this router, and i want to know the number>
What i've found on internet, is that is support up to 10 Cisco VPN Clients, but i've already tested it with 14 simultanious users, so i'm in doubt.
let me know
Emmanuel Valdez
Level 3
Level 3
Nowadays I have a customer with a Cisco 2821 for Internet connectivity and VPN Service with 200 VPN clients with factory RAM and Flash memory, if you check documentation this router can support up to 1500 VPN tunnels with AIM-EPII-Plus Module.
http://www.cisco.com/c/en/us/products/routers/2821-integrated-services-router-isr/index.html
You can use the CIsco 2821 with Easy VPN Server on Headquarters and Branch router with Easy VPN Remote.
I recommend you upgrade the IOS version to c2800nm-adventerprisek9-mz.124-20.T.bin
If it was useful please rate.
Regards.
Hi Lopez,
Please find the below Tunnel count and the below url to find the maximum tunnel supported VPN without any extra module i.e., embedded VPN feature.
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/prod_qas0900aecd80169bd6.html
 IPSec Performance and Tunnel Count by Platform
Platform
IMIX Traffic Mbps
1400 Byte Mbps
Maximum Number of Tunnels
Cisco 2801 with embedded VPN
14 Mbps
50 Mbps
150
Cisco 2801 with AIM-VPN/EPII-PLUS
30 Mbps
100 Mbps
1500
Cisco 2811 with embedded VPN
20 Mbps
55 Mbps
200
Cisco 2811 with AIM-VPN/EPII-PLUS
35 Mbps
130 Mbps
1500
Cisco 2821 with embedded VPN
36 Mbps
56 Mbps
250
Cisco 2821 with AIM-VPN/EPII-PLUS
70 Mbps
140 Mbps
1500
Cisco 2851 with embedded VPN
53 Mbps
66 Mbps
300
Cisco 2851 with AIM-VPN/EPII-PLUS
100 Mbps
145 Mbps
1500
Please Note: The Maximum Tunnel Scalability test is done with no data passing over the tunnels to only determine maximum number. So again it depends upon the factor that untill there is no problem with Bandwidth, CPU and Memory.
BR// Sanjay
Leo Laohoo
The main important question is this: What is the bandwidth of your WAN?
