What is "NAL PID" ?
Soon Kwan Kwon
 Hello all,
During searching about 3650 L2 switch, I found that there were odd sentence "NAL PID for 3650 24 Data 1 Gig LB switch"
In this sentence, I saw NAL first time.
To describe it to my customer, I should be well-acquainted with it.
Could you tell me what this mean by that?
SK.
*The data I found.
L3 Switch
Cisco 3650
  Cisco 3650 L3 Switch ( 10/100/1000 T, 24port, 2Y )
Cisco Catalyst 3650 24 Port Data 4x1G Uplink IP Base
SC CORE 8X5XNBD Cisco Catalyst 3650 24 Port Data 4x1G Up
CAT3650 Universal k9 image
250W AC Config 2 Power Supply
250W AC Config 2 Secondary Power Supply
Europe AC Type A Power Cable
Type 2 Stacking Blank
L2 Switch
Cisco 3650
  Cisco 3650 L2 Switch ( 10/100/1000 T, 48port, 2Y )
Cisco Catalyst 3650 48 Port Data 4x1G Uplink LAN Base
SC CORE 8X5XNBD Cisco Catalyst 3650 48 Port Data 4x1G Up
L2 Switch
Cisco 3650
  Cisco 3650 L2 Switch ( 10/100/1000 T, 24port, 2Y )
Cisco Catalyst 3650 24 Port Data 4x1G Uplink LAN Base
NAL PID for 3650 24 Data 1Gig LB switch
L2 Switch
Cisco 3650
5 Replies 5
Mark Malone
Hi maybe its to export to China you need NAL license to export there for telecomm devices - network access license
Thank you Mark,
Could you tell me abbreviation NAL??
If its the same thing NAL it is network access license
The Network Access License (NAL) is mandatory for telecommunication equipment that is exported to or sold in China. This license applies to telecommunication equipment that is connected to the public telecommunication network.
AH~~~ You already mentioned at first reply..!
Thank you so much!
The Cisco Catalyst 3650 Series is the next generation of enterprise-class standalone and stackable access-layer switches that provide full .... PID. Ports. Multigigabit Ports. PoE+. UPOE (60W). 4x1GE Uplink. 2x10GE/4x1GE Uplink. 4x10GE/4x1GE Uplink. 8x10GE/8x1GE Uplink. 2xQSFP+ Uplink ...
