Number of SVI supported in 1941/1921 router
raghav.rai
Hello All,
Is there any limitation on number of SVI interfaces supported in 1941/1921 router ?
Raghavendra
Joseph W. Doherty
I would expect there is, but often such limits are way beyond what you normally need in practice (except in some very extreme cases).
Do you need more than a hundred or a thousand?
acampbell
Looking at the url below, your SVIs just count as part of the tortal interface allowance the the IDB  (Interface Descriptor Block)
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-122-mainline/15096-idb-limit.html#addtl_idb_limitsisr
From TABLE 5 the 1900 range has a MAX of 1200 interfaces in total
Hope this helps.
Regards, Alex. Please rate useful posts.
