what is routing redistribution????
axus123456
Hello every one,
what is routing redistribution, for what we use it, why we use it and what it do???
i have seen this commandes on EIGRP configuration
redistribute connected metric *** *** *** *** **** route-map EIGRP_CONNECTED_OUT
redistribute connected metric *** *** *** *** **** route-map EIGRP_STATIC_OUT
as * is numbers
and also what below command do?
address-family ipv4 vrf secure
thanks
2 Accepted Solutions
kcnajaf
Level 7
Level 7
Hi Ala,
The use of a routing protocol to advertise routes that are learned by some other means, such as by another routing protocol, static routes, or directly connected routes, is called redistribution. Redistribution is often required when multiple routing protocol is used on a single device.
Redistribution is required to ensure that all routing protocol is aware of the networks learned by other routing protocols
On your above redistribution statement each set of ***** are the 5 EIGRP metric used during redistribution.
The formulae for calculating EIGRP metric is:
Metric = 256*((K1*Bw) + (K2*Bw)/(256-Load) + (K3*Delay)*(K5/(Reliability + K4)))
k1=bandwidth
k2=load
k3=delay
k4=reliability
k5=MTU
As far as i'm aware address-family ipv4 vrf secure is used to define a ipv4 version of VRF instance named as secure.
Najaf
Please rate when applicable or helpful !!!
You have 2 ways of advertising a prefix directly connected on your L3 device within an IGP: using a network command( which will  enable the IGP process on the corresponding interfaces and as a side effect advertise the corresponding prefix) or  redistribute connected interfaces( redistribute connected). By default all connected interfaces will be redistributed so here we can use a route-map to specify which connected prefixes to redistribute and also set them a particular metric.
Regards.
Alain
kcnajaf
Level 7
Level 7
Hi Ala,
k1=bandwidth
k2=load
k3=delay
k4=reliability
k5=MTU
Najaf
so basicly thats mean redistribute is used to advertise the routing information on a router to other routers on the same network,
Regards.
Alain
