Config help - BDI interface on an ASR
Bilal Nawaz
I saw the reply to this post:  https://supportforums.cisco.com/message/3761251#3761251 and I just  wanted to know what the configuration would look like on the ASR.
My main purpose for using a bdi interface will be routing  [ospf] (almost like router on a stick) There is a switch that is trunked  to the ASR interface and one of the vlans is to be a routed vlan. The  switch has an SVI on this vlan 595 but when it comes to the ASR, i need  an interface for that vlan too to form an OSPF neighborship
The interface on the ASR that connects to the trunk is below. The switch is trunking this vlan and is 802.1q tagged with 595...
interface GigabitEthernet0/0/2
no ip address
negotiation auto
cdp enable
service instance 4 ethernet
  encapsulation dot1q 4
  bridge-domain 4
service instance 5 ethernet
  encapsulation dot1q 5
  bridge-domain 5
service instance 595 ethernet
  encapsulation dot1q 595
  bridge-domain 595
interface bdi 595 .....
Any help would be much appreciated
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Giuseppe Larosa
Hello Bilal,
configuring an IP address under the BDI 595, and enabling OSPF for the same interface should be enough.
You need to take care of MTU in order to build a successful OSPF adjacency
Hope to help
Giuseppe
Giuseppe Larosa
Hello Bilal,
Hope to help
Giuseppe
Thanks Giuseppe,
I had to configure the ASR like this for it to work.
no ip address
negotiation auto
cdp enable
  bridge-domain 595
interface BDI595
ip address 192.168.231.5 255.255.255.192
ip ospf 1 area 1
encapsulation dot1Q 595
router ospf 1
router-id 192.168.231.5
network 192.168.231.5 0.0.0.0 area 1
Do you know why there is an option for interface vlan # when the command itself doesn't work?
Router(config)#inter
Router(config)#interface vl
Router(config)#interface vlan ?
  <1-4095>  Vlan interface number
Router(config)#interface vlan 595
% Invalid input detected at '^' marker.
Router(config)#
