What is the Delay of 10 Gigabit Ethernet?
Ravi_916
What is the Delay of 10 Gigabit Ethernet, 100 Gigabit Ethernet?
  1. Serial: Bandwidth: 1.544 Mbps, Delay: 20000 ms.
  2. Ethernet: Bandwidth: 10 Mbps, Delay: 1000 ms.
  3. FastEthernet: Bandwidth: 100 Mbps, Delay: 100 ms.
  4. 1 Gigabit Ethernet: Bandwidth: 1 Gbps, Delay: 10 ms.
  5. 10 Gigabit Ethernet: Bandwidth: 10 Gbps, Delay: ?
  6. 100 Gigabit Ethernet: Bandwidth: 100 Gbps, Delay: ?
Deepak Kumar
I never checked on the 100G but 10G interface delay would be:
DLY 10 usec
It is in the picoseconds.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
100 Gigabit is 10 msec as well...
HundredGigE0/5/0/24 is up, line protocol is up
Interface state transitions: 1
Hardware is HundredGigE, address is 6219.8864.e330 (bia 6219.8864.e330)
Internet address is 1.24.1.1/24
MTU 9216 bytes, BW 100000000 Kbit (Max: 100000000 Kbit)
reliability 255/255, txload 3/255, rxload 3/255
Encapsulation ARPA,
Full-duplex, 100000Mb/s, link type is force-up
output flow control is off, input flow control is off
--> Carrier delay (up) is 10 msec
loopback not set,
Last link flapped 10:05:07
ARP type ARPA, ARP timeout 04:00:00
Last input 00:08:56, output 00:00:00
5 minute input rate 1258567000 bits/sec, 1484160 packets/sec
5 minute output rate 1258584000 bits/sec, 1484160 packets/sec
228290765840 packets input, 27293508436038 bytes, 0 total input drops
0 drops for unrecognized upper-level protocol
Received 15 broadcast packets, 45 multicast packets
0 runts, 0 giants, 0 throttles, 0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
212467849449 packets output, 25733664696650 bytes, 0 total output drops
Output 23 broadcast packets, 15732 multicast packets
39 output errors, 0 underruns, 0 applique, 0 resets
0 carrier transition
