What is the difference between HWIC-2CE1T1-PRI & VWIC2-2MFT-T1/E1?
M.Zaatreh
Dears,
kindly I need to know what is the difference between these two cards HWIC-2CE1T1-PRI & VWIC2-2MFT-T1/E1:
1- where we can use each cards?
2- does the first card support voice?
3- what is the data PRI and what is the difference between it and T1/E1.
4- I know that the first card is higher price than the 2nd, so what does it has more features to make it more costly?
Thanks in advance.
Best Regards,
Mohammed Zaatreh
paolo bevilacqua
1 WIC-2CE1T1 is for data PRI, VWIC2-2MFT-T1/E1 for voice
2,.no
3. leaving alone what data PRI is, what do you need to do ?
4. no. different features.
5 Replies 5
paolo bevilacqua
2,.no
Thank you for your fast response, I think it's clear now, but I have another inquiry, when we say HWIC-2CE1T1-PRI does not support voice that mean we can't deploy a QoS on it? Thank you.
Best Regards,
Mohammed Zaatreh
No, it means you can't terminate voice calls with it.
Please remember to rate useful posts clicking on the stars below.
3)  ISDN is standards for simultaneous of digital transmission for (voice,video,data ). But normally the PRI and BRI is dedicated for data transmission.
     A T1 line consists of 23 B + 1 D channels (1.5 MB each channel with 64 KB) and E1 - 31B  + 1D Channel ( 2 MB) .
    Each B-channel carries data, voice, and other services. The D-channel carries control and signaling information.
M.Zaatreh
Dears,
Thank you all for this information.
Best Regards,
Mohammed Zaatreh
