What is the max PCMCIA flash card size for a 3662 router?
cjm2112
Just bought three 3662 routers with 128M Ram and 32M Flash to add to my CCNP lab. There is two PCMCIA slots (flash cards). What is the max PCMAIA (Flash cards) available? Looking to see if there's 64Meg+ cards available so I can store larger IOS's greater than my 32M internal flash. Also do the 3662 use what is called linear flash?
Thanks Chris
Danilo Dy
Internal FLASH maximum is 64MB which means 2 x 32MB 80-pin SIMM
PCMCIA FLASH maximum is 32MB which means 2 x 16MB
Dandy
