What is the recommended MTU size for GRE tunnel interfaces?
mrmarie
Hello
We have two Cisco 800 router connected via 4G between two sites (GRE Tunnel), the MTU size configured in tunnel interface (1476), so is this value correct or should I change it as some as some protocols do not pass.
Appreciate your help
1476 is the default. Try and also set the mss:
interface Tunnel0
--> ip tcp adjust-mss 1436
If that does not help, set the mtu to 1400 and the tcp adjust-mss to 1360.
Also, post the full running configuration of the router.
balaji.bandi
here is the over heads (from my documents)
GRE  Only set MTU to 1500-24 = 1476 byte
Overhead associated with IPsec and GRE
Encapsulation Overhead GRE only           |     24 bytes
IPsec (Transport Mode)                            |     36 bytes
IPsec (Tunnel Mode)                                |     52 bytes
IPsec (Transport Mode) + GRE                 |     60 bytes
IPsec (Tunnel Mode) + GRE                     |     76 bytes
Good reference :
https://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/25885-pmtud-ipfrag.html
BB
interface Tunnel0
GRE with IPSec total 1408 but it safe to be 1400
Joseph W. Doherty
As both Balaji and Georg have already noted, "standard" GRE headers consume 24 bytes, so typically you will, as you also note, set an interface's IP MTU (not interface's actual/physical MTU) to 1476.
Georg also makes a good suggestion about using the adjust-mss command.  However, the 1436 value assumes standard/usual/minimal sized IP and TCP headers are being used.  (NB: there's other good information in the document that Balaji provided the link to.)
BTW, have you tried pinging across this link, using a DF setting with various packet sizes?
