What is this message about?
kanno
Hi All ...
I have a 2821 with Advanced Security 12.4(24)T IOS, and the following messages was logged during an outtage of the router. The router operation (ssh access) became very slow, and the network traffic was compromised.
997506: Jul 29 12:40:00.510 BRA: %SYS-3-INVMEMINT: Invalid memory action (free) at interrupt level, -Traceback= 0x42AF8DDCz 0x4154C864z 0x41548C88z 0x41531D6Cz 0x42222610z 0x42223A94z 0x4038A840z 0x4054AA40z 0x40546AB8z 0x402E8A28z 0x4000FF4Cz 0x40011570z
997507: Jul 29 12:43:55.809 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997508: Jul 29 12:43:55.813 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997509: Jul 29 12:43:55.813 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997510: Jul 29 12:43:55.821 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997511: Jul 29 12:43:55.833 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997512: Jul 29 12:43:55.845 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997513: Jul 29 12:43:55.853 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997514: Jul 29 12:43:55.865 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997515: Jul 29 12:43:55.873 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997516: Jul 29 12:43:55.881 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997517: Jul 29 12:43:55.885 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997518: Jul 29 12:43:55.885 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997519: Jul 29 12:43:55.885 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997520: Jul 29 12:43:55.885 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997521: Jul 29 12:43:55.889 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997522: Jul 29 12:43:55.889 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997523: Jul 29 12:43:55.889 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997524: Jul 29 12:43:55.897 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997525: Jul 29 12:43:55.901 BRA: CCE: CCE 7 tuple table entry to add not malloced.
997526: Jul 29 12:44:12.429 BRA: %SYS-3-INVMEMINT: Invalid memory action (free) at interrupt level, -Traceback= 0x42AF8DDCz 0x4154C864z 0x41548C88z 0x41531D6Cz 0x42222610z 0x42223A94z 0x4038A840z 0x4054AA40z 0x40546AB8z 0x402E8A28z 0x4000FF4Cz 0x40011570z
The SYS-3-INVMEMINT message ocasionally appears, but the CCE message is new, and was first seen during the router outtage.
Does anyone knows what these messages means?
Thanks in advance.
Laurent Aubert
Those messages are related to a memory leak. You should open a SR so the TAC will be able to identify the right bug.
Laurent.
Hi Laurent ...
I will contact TAC.
Thanks for your reply.
Sergio.
Just from my past experience,
Any "Malloc" err is possibly a bug or something bit critical yet may show up intermittently, and one should contact TAC as soon as possible.
