10-20-2016 08:21 AM - edited 03-05-2019 07:19 AM
Hi What kind of cable/fiber can be used for ethernet or serial interface? I think the physical interface decide it is Ethernet or serial cable/fiber. Anyone can give some explanation or link? Thank you
10-20-2016 09:50 AM
here is a pretty good link. Keep in mind that nowadays, pretty much anything can connect with anything. There are e.g. serial to Ethernet connectors...
http://www.computernetworkingnotes.com/ccna-study-guide/cabling-cisco-devices-guide.html
10-20-2016 12:13 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What it's designed to support.
Some times it might only support one specific cable. Other times, various cabling options are possible. Choice often determined by bandwidth and distance that needs to be supported.
Unfortunately, I don't believe I've seen a single link that addresses the breadth of your question.
For same reason, "some explanation" would be very long.
Try searching (Internet, Wiki, Cisco's main site) for cat3, cat5, cat5e, cat6, cat6a and cat7 to address copper Ethernet. For fiber, there's different variants of MM and SM fiber. Then with those go different optics to support different distances and technologies.
For serial, try initially searching for RS (EIA/TIA) - ### standards or the V.## standards.
You might also try a question like this on Cisco's learning forums.
10-21-2016 09:45 AM
For Ethernet, broadly speaking, there are two options and these are:
You choose the appropriate one using the media-type cmd. The anchored link refers to some legacy options which are no longer relevant. In today's networks, the options are rj45 OR sfp.
Typically, you may want to pose the question to your service provider. They can provide the accurate and more importantly the precise/specific answer.
Kind regards .... Palani
