What kind of router support IOS SLB
mingchieh
Hello ! Can I implement IOS SLB on router
(like 3660,28xx,38xx) ?
sachinraja
Level 9
Level 9
see if this document helps you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5014/products_feature_guide09186a00800eda88.html
it has config examples of IOS SLB.. make sure your router has the right IOS that supports SLB.
hope this helps.. all the best.
Raj
as per the doc, it is supported only on 6000 / 7200 series routers.. am afraid you cannot run it on smaller routers...
Raj
