Sample config on 837 ADSL router
vincent-n
Level 3
Level 3
Hi all
I'm in Australia and has subscribe to Telstra's BigPond Internet services via an ADSL link and would like to know where I can find a simple, basic ADSL config that I can use. My router is equipped with a firewall feature set which I'm thinking of connecting this router to the corporate network via a VPN connection. Any help would be greatly appreciated.
sachinraja
Level 9
Level 9
Hi vincent
you will find the various scenarios with respect to ADSL configaration on the URL below:
http://www.cisco.com/en/US/tech/tk175/tk15/tech_configuration_examples_list.html
you need to ask ur ISP for the exact scenario, eg pppoe.. they will infact give you the required information/configuration.
hope this helps.. all the best..
Raj
Depends. What sorta router are you running?
Telstra should have pointed you in the right direction, call them up...
Josef.
