What or how define de real bandwitch
leonardoortiz
I know that the bandwitch command is use for QoS and protocols, so, what define the real bandwitch of one serial interface ?
What define that my router comunicate with other, in other city, with 2048Mbps ?
Richard Burts
The real bandwidth for a serial interface is determined by the clocking supplied for that circuit.
Rick
Rick
Ok, this can be a "clock rate" or some QoS method ? Traffic Shaping, class map ...?
I dont know if u can understand me, but, how my router know the bandwitch of the other side (ISP) is providing ?
Sorry for my english :/
Your router won't know the bandwidth supplied by the ISP unless it's configured as such.
If you are subscribed to a sub-rated service, we recommend configuring QoS to avoid drops in the ISP side.
For instance, if you have a DS3 serial interface and you've only purchased half of that, the router will attempt to deliver up to 45Mbps and the ISP router will drop data over 22.5Mbps.
Hope this helps.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I think serial interfaces will "pick up" the clock rate for their bandwidth.  If not, or on any interface where available end-to-end transit bandwidth is less than what the physical interface supports, the bandwidth statement will "inform" other "things" about the interface bandwidth (although it won't, by default, limit the interface's physical bandwidth).
