What ports need to be open for SIP phones to work?
mchance
With the help of Tim Y i created an ACL to prevent several vlans from accessing my management vlans. The ACL works as intended for the WIFI access point public vlan. The SIP vlan will not work however. IF I do not restart the SIP phone the it will continue to work as it should for about an hour. If I restart the phone it shows "network down" and "DHCP Fail". What am i missing? What else needs to be open to make the SIP phones work?
interface Vlan10
description MANAGEMNET
ip address 172.16.110.1 255.255.255.0
ip helper-address 172.16.110.29
ip helper-address 172.16.111.13
no ip redirects
interface Vlan12
description PHONE
ip address 172.16.112.1 255.255.255.240
ip access-group No_Management in
interface Vlan17
description PUBLIC WIFI
ip address 172.16.117.129 255.255.255.192
ip access-list extended No_Management
permit udp 172.16.117.128 0.0.0.127 host 172.16.111.13 eq bootpc
permit udp 172.16.117.128 0.0.0.127 host 172.16.111.13 eq domain
permit udp 172.16.117.128 0.0.0.127 host 172.16.110.29 eq bootpc
permit udp 172.16.117.128 0.0.0.127 host 172.16.110.29 eq domain
deny ip 172.16.117.128 0.0.0.127 172.16.111.0 0.0.0.255
deny ip 172.16.117.128 0.0.0.127 172.16.110.0 0.0.0.255
permit ip 172.16.117.128 0.0.0.127 any
permit udp 172.16.112.0 0.0.0.15 host 172.16.111.13 eq bootpc
permit udp 172.16.112.0 0.0.0.15 host 172.16.111.13 eq domain
permit udp 172.16.112.0 0.0.0.15 host 172.16.110.29 eq bootpc
permit udp 172.16.112.0 0.0.0.15 host 172.16.110.29 eq domain
deny ip 172.16.112.0 0.0.0.15 172.16.111.0 0.0.0.255
deny ip 172.16.112.0 0.0.0.15 172.16.110.0 0.0.0.255
permit ip 172.16.112.0 0.0.0.15 any
EDIT: I changed my ACL to one that should allow all traffic from vlan 12 to my DC's and it still does not work.
permit ip 172.16.112.0 0.0.0.15 host 172.16.111.13
permit ip 172.16.112.0 0.0.0.15 host 172.16.110.29
6 Replies 6
This tells me what ports SIP phones use but does not tell which ports SIP phones need open to DHCP and DNS.
I may be missing something else. I changed the ACL to:
That should allow all traffic to my DC's however even with that ACL the phones will not work.
Hi!
Please refer to port 53 for DNS and port 67 for DHCP (or bootpc if using a helper-address and the ACL is used as IN).
Here is the documentation for the DHCP ports in case you feel like going more in depth:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/xe-3se/3850/dhcp-xe-3se-3850-book/config-dhcp-server.html
Hope it helps, best regards!
JC
Those are the ports I used in the ACL that is being used for vlan 17. It works fine for computer traffic.
I also tried in addition to bootpc, ports 37, 49, 53, 67, 68, 69, 137 and 138. The SIP phone will not work.
The ACL is applied as IN.
Which is the SIP VLAN?. VLAN 12?
Yes, vlan 12 is the SIP vlan.
