What relation between the two physical interface in Nexus7000 Fex?
wfqk
Level 5
Level 5
Hi, The Nexus7000 has two below interface configuration, which are all connected to FW1. 141 is one of Fex. The interface Ethernet6/4 should be one of ports of line card. I am not sure what is relation between the two interface. This two interfaces are separate physical interface, or only one interface? Any expert can give some suggestion? Thank you
  description FW1
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 3,19
  spanning-tree port type edge trunk
  udld aggressive
  no shutdown
interface Ethernet141/1/6
  description FW1
  switchport
  switchport trunk native vlan 99
  spanning-tree guard root
  speed 10000
  duplex full
2 Accepted Solutions
Vinit Jain
Those two are two separate physical interfaces for sure. i only see a difference from the configuration perspective where in the FEX port has the native vlan set to 99 and has root guard enabled.
The best thing would be to physically check the FW or Nexus on where these two connections are going (unless there is some cabling information available with you)
Vinit
--Vinit
Interface Ethernet141/1/6 is the fex interfac e could you please check what is connected onto this port?
show int E141/1/6 ?
12 Replies 12
Vinit Jain
Vinit
--Vinit
Thank you for your reply. The command "show ip arp" should be helpful to the issue, but the command cannot show any thing in the Nexus7k.
Rather than the show ip arp, check out the command show mac address-table <int>. That might provide the set of mac addresses learnt over the link.
--Vinit
show mac address-table can show mac address in interface Ethernet6/4, but interface Ethernet141/1/6 has no output.
show int E141/1/6 ?
it shows it is down. Thank you
There you go..If it is down then looks to be nothing connected to the same :-)
yes, the issue has been solved. thank you
Hey ,
Could you do a favour , please mark the thread as answered as I see you have got the information required so that this query thread is closed rather than keeping it as unanswered questions. Thanks in advance.
Inayath
I had rated it, and so I thought it is closed. Now i just did it again. please let me know it if there is still any issue. Thank you!
Thank you for taking a time to get this thread closed
Rating would not closed the thread as answerd question.You need to select correct answer only then the thread would get closed.
Good to know. Thank you for your answering my question.
