DMVPN tunnels not working
Brian Tulloch
I am installing a point to multipoint network using DMVPN. All the DSL links come up and I can ping the public IP of the other router, but not through to the 192.168 (LAN) side. Presumably a simple mistake, but I am a little stuck. I have a 2901 as the hub, and 800 series for the spokes.
Using CiscoConfigProfessional, IPsec tunnels are up, but DMVPN tunnels do not exist.
I get the following messages "rec'd ipsec packet has invalid spi for destaddr"
All suggestions appreciated.
Each router has 5 connected subnets, all of which need to route across the WAN.i.e.
the hub has 192.168.0.x, 192.168.1.x, 192.168.2.x,192.168.3.x, 192.168.4.x,
spoke 1 has 192.168.8.x, 192.168.9.x, 192.168.10.x, 192.168.11.x, 192.168.12.x
spoke 2 has 192.168.16.x, etc
The hub router has the following configuration:
hostname hub
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone PCTime 10 0
ip name-server 203.50.2.71
ip name-server 139.130.4.4
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2901/K9 sn FGL195320YQ
username xxxxx privilege 15 secret 5 xxxxx
redundancy
controller VDSL 0/0/0
crypto keyring ccp-dmvpn-keyring
pre-shared-key address 0.0.0.0 0.0.0.0 key 074842abcd
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp profile ccp-dmvpn-isakmprofile
match identity address 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile ccp-dmvpn-isakmprofile
interface Tunnel0
bandwidth 1000
ip address 192.168.254.1 255.255.255.0
ip mtu 1400
no ip split-horizon eigrp 99
no ip next-hop-self eigrp 99
no ip redirects
ip nhrp authentication DMVPN_NW
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
delay 1000
tunnel source Dialer0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.254 255.255.255.0
ip address 192.168.1.254 255.255.255.0 secondary
ip address 192.168.2.254 255.255.255.0 secondary
ip address 192.168.3.254 255.255.255.0 secondary
ip address 192.168.4.254 255.255.255.0 secondary
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0/0/0
no ip address
interface Dialer0
ip address 144.139.198.112 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxx@direct.telstra.net
ppp chap password 0 xxxxx
ppp pap sent-username xxxxx@direct.telstra.net password 0 xxxxx
router eigrp 99
network 192.168.0.0 0.0.7.255
network 192.168.0.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 144.139.198.1
dialer-list 1 protocol ip permit
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
banner login ^CThis is the hub
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
hub 72 configuration is
version 15.3
hostname hub72
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging buffered
enable secret 5 $1$bAhU$/QlanXdT2nZxxxxxxxx
enable password xxxxxxx
no aaa new-model
clock timezone ESTime 10 0
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FGL2006224M
username xxxxx privilege 15 password 0 xxxxx
controller VDSL 0
encr 3des
group 2
crypto isakmp key xxxxx address 144.139.198.112
mode transport
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-SHA3 esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-3DES-SHA4 esp-3des esp-sha-hmac
mode transport
set transform-set ESP-3DES-SHA4
interface Tunnel0
bandwidth 1000
ip address 192.168.254.72 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 192.168.254.1 144.139.198.112
ip nhrp nhs 192.168.254.1
delay 1000
tunnel destination 144.139.198.112
tunnel key 100000
interface ATM0
no ip address
pvc 8/35
interface Ethernet0
no ip address
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description Wired LAN interface
ip address 192.168.72.254 255.255.255.0
ip address 192.168.73.254 255.255.255.0 secondary
ip address 192.168.74.254 255.255.255.0 secondary
ip address 192.168.75.254 255.255.255.0 secondary
ip address 192.168.76.254 255.255.255.0 secondary
ip nat inside
interface Dialer0
description WAN Interface
ip address 149.135.115.72 255.255.255.0
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
router eigrp 99
network 192.168.72.0 0.0.7.255
network 192.168.254.0
ip http server
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 permit 192.168.72.0 0.0.7.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
password 22xxxxxx
login
transport input all
Tim Y
It looks like there's a lot of things amiss with the configuration. At first glance, I'd look into the following:
  • Change the
    access-lists
    you're using for NAT to extended
    access-lists
    and deny the networks that you want to talk to each other over the DMVPN from being included in the NAT
  • The crypto keyring is missing from the DMVPN hub. The hub and spoke should both have this command with the key matching
  • Remove the tunnel destination command from the spoke - it doesn't need it. It can find the hub via the mapping and the nhs setting
  • Set the tunnel mode of the spoke to be: tunnel mode gre multipoint
I would start with that. If you're still having issues, look over this guide and compare the configurations: http://www.internetworkingcareer.com/vpn/configure-dmvpn-phase-2-eigrp/
Hope this helps!
Tim
Tim Y
  • Change the
    access-lists
    access-lists
Hope this helps!
Tim
Thanks Tim,
I used the link you supplied, and re-wrote the config using that as a guide. It works! Thanks for your help.
Brian
Great! Have a good one!
Tim
Hi Tim,
hoping you can help again. I had the network up using a DSL at the hub, but the
bandwidth was woeful. We then upgraded to a dedicated radio link, and changed the configs to suit. On the spoke, I changed the mapping to the new ip address, but on the hub the DSL was replaced with a FastEthernet card. All the links have come up and I can browse the internet and ping the public IP of the other router, but not through to the 192.168 (LAN) side.
Revised configs below.
hostname hub
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
redundancy
crypto keyring DMVPN
pre-shared-key address 0.0.0.0 0.0.0.0 key 0748423900
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp invalid-spi-recovery
crypto ipsec security-association replay disable
crypto ipsec transform-set cws-dmvpn-trans esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile DMVPN-EX
set transform-set cws-dmvpn-trans
interface Tunnel100
bandwidth 1000
no ip redirects
ip mtu 1400
ip pim sparse-dense-mode
ip nhrp authentication VPN100
ip nhrp holdtime 450
delay 1000
tunnel source FastEthernet0/0/0
tunnel key 99100
tunnel protection ipsec profile DMVPN-EX shared
no ip address
ip address 192.168.5.254 255.255.255.0 secondary
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
ip address 202.144.180.51 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 99
passive-interface default
no passive-interface Tunnel100
ip http server
ip nat inside source list 1 interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 202.144.180.254
access-list 1 remark CCP_line con 0
access-list 1 permit 192.168.0.0 0.0.7.255
access-list 1 permit any
control-plane
banner login ^C This is the Mackay Base Hospital services routerfor support, call Group
CCTV
on 07 048423900 ^C
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
version 15.3
hostname hub72
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging buffered
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
encr 3des
group 2
mode transport
! This sets the tunnel parameters. Network 192.168.254.x is used for the tunnel
interface Tunnel100
bandwidth 1000
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
! this maps the hub tunnel address to the public address and vpn number
ip nhrp map 192.168.254.1 202.144.180.51
delay 1000
tunnel key 99100
interface ATM0
no ip address
pvc 8/35
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxx@direct.telstra.net
ppp chap password 0 1xxxxx
ppp pap sent-username xxxxxxxxx@direct.telstra.net password 0 xxxxx
router eigrp 99
ip http server
ip route 0.0.0.0 0.0.0.0 149.135.115.1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password 22882288
login
transport input all
