What router is/has replacing the 2600/2600xm series?
nixonjer07
What series of routers is/has replacing the functionality of the 2600/2600xm series routers?
Thanks in advance,
Jer
5 Replies 5
nixonjer07
I guess it would be the 3800 series? the cost on these routers are quite high, so I'm assuming the 2600xm's will be around for quite some time yet?
thanks,
Jer
Actually the replacement is the 28xx, with the more similar being the 2811 and the smaller 2801 that is like the 1760.
The 38xx are more the replacement for 37xx series (25 and 45).
Ok that makes sense. What did the 1800 series replace then ? Or is it a whole new platform?
Thanks for the information..
Jer
The 1800's replaced the 1700's except the 1800's will only support VWICS with data only, so then you would have to go with a 2800.
Rumors exists about a "communications series 500" that could take the place of the now EOS 1751-V.
