What Router should I deploy
asfar.zaidi
Hi Guys
Please guide me in buying router for my branches,
Is one router will be enough or I dont know what will be the design , please guide to achieve my following requirements :
- On Branch Office I will be connecting through MPLS as primary link
- IPSec VPN over ADSL will be my Secondary link.
- More than 100 users will be there in my each branch office.
6 Replies 6
m-haddad
Level 5
Level 5
What are your links speed going to be?
MPLS Link will be 4 MB
ADSL Link will be 2 MB
Hi, as small as a 1841 will do fine.
Thanks , now can you please help me by telling me how will i configure MPLS link as my primary and IPSec VPN over the ADSL as my secondary or backup link.
If you have any sample configuration that will be great help.
It is a kind of advanced configuration, do you want to take it alone using documentation only ? You should look for dmvpn then.
Yes i can do it alone
