What Tech shall i use to connect 3 DCs
Ibrahim Jamil
Level 6
Level 6
Hello freinds
What Tech shall i use to connect 3 Dispersed  DCs? Application mobility requirement
1. H-VPLS
2. OTV
3. VXLAN EVPN
4. PBB EVPN
pls Adivise on the Pros and Cons for each tech  , i m really confused
nazimkha
Level 4
Level 4
Depends on your existing infra
Ibrahim Jamil
Level 6
Level 6
MPLS Provider will be the transport
I understand MPLS would be transport but choice of the DCI will depend on the equipment in your data center.
For example, if you dont have Nexus 7K, ASR or other devices which support OTV, you cannot do the same.
If you are not running devices which support VXLAN capabilities than VXLAN EVPN DCI would not be feasible.
If you can give the details of the existing data center then we could suggest some suitable option
Hi Mate
VXLAN EVPN supported on N7K and N9K and  ASR as well
 I m thinking to go PBB-EVPN
thanks all
