05-12-2016 03:14 AM - edited 03-05-2019 04:00 AM
KIndly provide the solution with an explanation.
Any help would be appreciable.
05-12-2016 03:40 AM
depends on platform , IOS and NX-OS are different but the general theme is 4096 vlans that's whats allowed in the database at layer 2 , so you cant have a layer 3 vlan without layer 2 first or it wont work , that's the RFC IEEE 802.1Q amount the standard of any switch platform but NX-OS is slightly different in how it operates in the number ranges
If being specific its 1 -1001 are general vlans then 1002-5 are reserved and then 1006 - 4096 are extended vlans which are now supported in vtp v3
03-13-2018 05:05 AM - edited 03-13-2018 05:06 AM
it does not depend of the capability if it is L2 or L3, the maximum supported VLANs depend of the platform. Usually the maximum supported is 4096 VLANs.
