What would you recommend ?
S Kumar
Hi all,
We have the following :
  • GigE ehternet circuit from ISP via fiber.
  • Cisco 7206 (NPE-G2) Router
  • Cisco 2960G Ethernet Switch
  • All devices which process public traffic are also connected to ethernet switch.
What would you recommend:
  • Connecting ISP directly to Router and then connecting router to the Ethernet Switch  OR
  • Connecting both ISP and router to Ethernet Switch.
What are the advantages/disadtantages in either case?
Leo Laohoo
Connect the ISP to the router.
leolaohoo,
Thanks for your time. What is the advantage of connecting it to the router?
The disadvantage for connecting to a router is the number of ports your router have left.
The advantages of having the router is traffic shaping, QoS, firewalling, ACL, etc.
Talha Ansari
C2960 is a layer 2 switch so the link from your service provider must be terminated on your router since your switch doesnt have routing capability.
