Whats wrong with this RIP Configuration?
veddotcom
I am attaching the packet tracer file "Wrong Rip.pkt", in which i have configured networks as in the pic http://i.lulzimg.com/7c8a2d69de.png , The problem is when i remove the network 10.1.4.0 from the scene, everything works perfectly i.e each router can communicate with each other but when its in the design router networks unable to talk... What am i doing wrong???
5 Replies 5
cadet alain
for VLSM support and discontiguous networks like in your topology you must use RIP v2 and disable auto-summary.
on all routers:
conf t
router rip
ver 2
no auto
do clear ip route *
then verify all the networks are in the routing table: sh ip route rip
Regards.
Alain
I understand this could be problem of Discontinous network, but how it is supposed to be VLSM??
Yep you're right the mask is /24 everywhere , I answered too fast for the VLSM thing.
Regards..
Alain
Thanks..i will read about discontinous networks then..
Don't forget to rate helpful posts and mark the thread as solved if your problem is resolved.
Regards.
Alain
