Which device can covert NxT1 into Ethernet?
news2010a
Level 3
Level 3
I was told it is possible to get 2xT1 and convert this into Ethernet via a type of device and deliver to the CPE (router) as Ethernet.
Does this work well?
Which is the device capable of delivering that?
Marwan ALshawi
Not sure if there is device like ntu to fo this
But a voice gateway can interface between tdm isdn and ip packet switched network !
are you looking for something similar to this?
http://www.blackbox.com/Store/Detail.aspx/1-Port-T1-E1-Ethernet-Network-Extender-Kit/LR0301A%C4%82KIT
or
http://www.rad.com/10/T1-Serial-and-Ethernet-Interface-Converter/3214/#
i would suggest against using that since that device will be additional point of failure..you can use MFT wics supported on your router then bundle them up into a multilink which would be better costwise and maintenance wise.
hth
