Which IOS supports MPLS
Manoj Wadhwa
Hello Friends,
Can anyone suggest me which IOS version on 3620/ 3640 support MPLS (frame mode). I've been struggling to find one. Thanks in advance.
Manoj
5 Replies 5
jamalbelarj
If you go to:
Cisco Software Advisor (http://tools.cisco.com/Support/Fusion/FusionHome.do)
Choose platform and features you want, You need to have a login to CCO.
I did an initial checkup and it doesn't look like 3600 series support MPLS.
Regards.
Jamal
Hi Jamal,
Can you advice the exact IOS for any other model (1700, 2600, 3700, 7200 ). I am trying to find using the link you provided but if you already know the exact version as per your experience, it will be helpful. Thanks again.
Manoj
for 3725:
Software Image (Latest Maintenance Release in Train):
c3725-advipservicesk9-mz.12.4-6.XT2
Thanks.
Istvan_Rabai
Level 7
Level 7
Hi Manoj,
I checked on the Cisco website:
For 3640 routers, IOS versions 12.4(1) Enterprise Plus and above surely support MPLS.
Here's the link to the Cisco feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Cheers:
Istvan
Giuseppe Larosa
Hello Manoj,
C3640 is fine for MPLS I'm afraid C3620 doesn't support it
a good platform is C2600XM and there is difference with normal c2600.
C3700 and C7200 are really good for this.
Hope to help
Giuseppe
