Which IOS to download for my Cisco 887 device....
Elrick Landon
I would like to updrage IOS for my 887 Cisco ADSL/Router.
I found a firmware version named c800-universalk9-mz.SPA.154-3.M3.bin but my rom is named c880xxxxxxxxxxxxxx
When i put the c800 firmware, it says "%Warning: File not a valid executable for this system"
So i have a doubt about the IOS to take, i do a show version to be sure.
Someone can give me the filename and path of the lastest IOS for my device please ?
show version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
System image file is "flash:c880data-universalk9-mz.150-1.M1.bin"
Cisco 887 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ141692W5
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO887-SEC-K9       FCZ141692W5
License Information for 'c880-data'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Configuration register is 0xE442
Many thks for your help.
The release notes for 15.4.3.M3 do not include the plain 887 in the supported hardware listing.
The release notes for the version I recommended do include it.
If you're downloading IOS images, you must be eligible for TAC support. So feel free to open a case to confirm.
5 Replies 5
Marvin Rhoads
Always check the release notes, especially for end of sales products like yours.
According to the IOS release notes (link), the last release for the 887 router (non-VA base model) is IOS 15.2.4M8 (10 Apirl 2015).
The image file name would be "c800-universalk9-mz.SPA.152-4.M8.bin". It can be found here.
The UNIVERSAL, c800-universalk9-mz.SPA.152-4.M8.bin is release on APRIL 2015.
On Cisco web site, they suggest to use UNIVERSAL c800-universalk9-mz.SPA.154-3.M3.bin (JUNE 2015)
I try to boot with it and it doesn't work, see error message below ... normaly this release is newer and compliant too ?
Readonly ROMMON initialized
loadprog: error - Invalid image for platform
e_machine = 221, cpu_type = 180
boot: cannot load "flash:c800-universalk9-mz.SPA.154-3.M3.bin"
Does i need to update ROMMON ? it seems that i have the lastest ROMMON for my device
Many thks for your advise.
Thks you for this information... more clear for me :)
I don't have access right to download this IOS (Service Contract Required), i need to find it on the web or find someone to give it me.
Anyway, not normal to pay for update his device.
It is quite normal to pay for updated IOS as part of the services a support contract entitlement.. That's been Cisco's model across the majority of their products for over 30 years and it is a model shared among many networking vendors.
If you don't agree with the terms of Cisco's licensing and aren't entitled to download them for your device, then you shouldn't be using the images in violation of those terms.
