05-09-2005 05:17 PM - edited 03-03-2019 09:30 AM
Hi All,
When use 2 supervisor engine in 4500 or 6500, by default which one will be the primary one? or the system will randomly choose one as primary? how to determine which one is primary supervisor engine?
Thank You!
Best Regards
Teru Lei
Solved! Go to Solution.
05-09-2005 06:09 PM
Normally it would be the Supervisor in slot 1. In CAT4500, we had seen instances in which slot 2 would become active. This issue has been fixed in 12.2(25)EWA.
Hope this helps
05-09-2005 06:09 PM
Hope this helps
05-09-2005 07:16 PM
Hi prkrishn,
Thank you! So I know why one of my customers' 4500 sometime use slot 2 as primary supervisor engine.
Best Regards
Teru Lei
