04-20-2006 09:35 AM - edited 03-03-2019 12:27 PM
I have looked and cannot find a reason for the "Keepalive 2" statement in a 2950 switch.. TIA
Solved! Go to Solution.
04-20-2006 09:40 AM
By default, I believe keepalives are not sent out of the interface. Setting 'keepalive 2' will sent out a keealive message every 2 seconds.
Paresh
04-20-2006 09:40 AM
Paresh
04-20-2006 09:44 AM
thank you Paresh!
I know this about keepalives, but do not know why it applies here...
I understand to use (as an option) to set keepalives on WAN interfaces, but do not know about Fast Ethernet.. is it VoIP related?? thanks
Robbie
04-20-2006 10:10 AM
Hi Robbie,
The keepalive packets are part of a loopback detection mechanism. If a port receives a keepalive that it had sent, then the switch will disable the port to prevent a layer 2 loop.
HTH,
Bobby
*Please rate helpful posts.
